Введение
This guide is an internal private guide used as a prereq.
Выберете то, что вам нужно
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Еще один человек закончил это руководство.
you do not need to remove the battery when replacing the hard drive or ram
brilldoctor - Ответить
beware not to lift the connector to close of the angle, as the picture suggest it. It might broke the angle. Attack by the middle.
naamol - Ответить
Not necessary?
hikkymemo - Ответить
Be careful of the corner of the battery cable connector when trying to pry it off with the spudge. I knocked the corner of mine. No operational impact but was not very pleasing!
jljordanweb - Ответить
Not necessary, but a good idea, so as to avoid any spurious charges going through the boards...
svenaustx - Ответить
@Svenaustx - What could happen if not removing this battery? Worst case? Not a geek on this but did change RAM on my Macbook Pro "15. Can't remember disconneting the battery back then. Shouldn't it be sufficient shutting the Mac off and ensure it has been used for an hour or so before replacing RAM?
Allan Clarke -
i used a metal pry and noticed some sparking when i disconnected the battery. replaced ram. now it wont turn on. did i fry it?
Ian Lynch - Ответить
