Введение
Replacing a defective fan will keep your laptop running cool.
Выберете то, что вам нужно
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use a spudger to pry the AirPort/Bluetooth ribbon cable connector straight up off the logic board.
Gently bend the AirPort/Bluetooth ribbon cable away from the fan.
Use the flat end of a spudger to pry the fan connector straight up off the logic board.
Remove the following three screws securing the fan to the upper case:
One 7.1 mm Phillips
Two 5.3 mm Phillips
79 участников успешно повторили данное руководство.
3 Комментариев
Wish I had read Maurices comment. I did this fix because my fan had a noisy bearing. But I found the sound of the fan running at full speed after the replacement to be more annoying. So I swapped it back. didn’t think top reset the SMC.
