MacBook Unibody Model A1342 Fan Replacement
Выберете то, что вам нужно
  1. MacBook Unibody Model A1342 Fan Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Fan Replacement: шаг 2, изображение 1 из 3 MacBook Unibody Model A1342 Fan Replacement: шаг 2, изображение 2 из 3 MacBook Unibody Model A1342 Fan Replacement: шаг 2, изображение 3 из 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 Fan Replacement, Battery: шаг 3, изображение 1 из 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 Fan Replacement, Fan: шаг 4, изображение 1 из 1
    • Use a spudger to pry the AirPort/Bluetooth ribbon cable connector straight up off the logic board.
    • Gently bend the AirPort/Bluetooth ribbon cable away from the fan.
  5. MacBook Unibody Model A1342 Fan Replacement: шаг 5, изображение 1 из 3 MacBook Unibody Model A1342 Fan Replacement: шаг 5, изображение 2 из 3 MacBook Unibody Model A1342 Fan Replacement: шаг 5, изображение 3 из 3
    • Use the flat end of a spudger to pry the fan connector straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Unibody Model A1342 Fan Replacement: шаг 6, изображение 1 из 1
    • Remove the following three screws securing the fan to the upper case:
    • One 7.1 mm Phillips
    • Two 5.3 mm Phillips
  7. MacBook Unibody Model A1342 Fan Replacement: шаг 7, изображение 1 из 1
    • Lift the fan out of the upper case.
Заключение
81 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
Replaced the fan with an used one. After booting the fan made a very loud sound as if it was running on max speed. A SMC reset fixed the issue and the fan returned to normal speed and sound.
[deleted] - Ответить
Wish I had read Maurices comment. I did this fix because my fan had a noisy bearing. But I found the sound of the fan running at full speed after the replacement to be more annoying. So I swapped it back. didn’t think top reset the SMC.
Paul Ceccato - Ответить
Simple and concise…Thanks a whole bunch for the instructions.
Glenn - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 22
За последние 30 дней: 117
За всё время: 45,170
