Введение
Replacing your lower case is easy! It only takes 8 screws.
Инструменты
Запчасти
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Slightly lift the lower case near the vent opening.
Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
70 участников успешно повторили данное руководство.
2 Comments
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
