Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is an internal private guide used as a prereq.
Выберете то, что вам нужно
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Remove the following screws securing the right speaker assembly to the upper case:
One 12 mm Phillips screw.
One 3 mm Phillips screw.
Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
De-route the long antenna from its channel in the rear speaker housing.
Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
