Введение
This guide will walk you through the steps of replacing the screen of your Macbook Pro.
  1. Macbook Pro Glass  Replacement, Prepare a Workspace: step 1, image 1 of 1
    • Set up a clean workspace and gather all supplies. You will need your Macbook Pro, a new screen, a hair dryer, a screen cleaning cloth, and a suction cup.
  2. Macbook Pro Glass  Replacement, Heat the Edges of the Screen: step 2, image 1 of 2 Macbook Pro Glass  Replacement, Heat the Edges of the Screen: step 2, image 2 of 2
    • Use a hair dryer to heat the adhesive around the edges of the screen you are removing.
  3. Macbook Pro Glass  Replacement, Use suction to remove the Screen: step 3, image 1 of 3 Macbook Pro Glass  Replacement, Use suction to remove the Screen: step 3, image 2 of 3 Macbook Pro Glass  Replacement, Use suction to remove the Screen: step 3, image 3 of 3
    • Attach the suction cup found in the iFixit repair kit to the corner of your screen, by gently pressing down until it seals. Lift screen away by pulling up on the suction cup key ring.
  4. Macbook Pro Glass  Replacement, Preparing for the New Screen: step 4, image 1 of 2 Macbook Pro Glass  Replacement, Preparing for the New Screen: step 4, image 2 of 2
    • Use a screen cleaning cloth to buff out any marks on your Macbook Pros screen surface.
    • Use a screen cleaning cloth to buff out any marks on the inside of new glass that will be applied.
  5. Macbook Pro Glass  Replacement, Preparing Screen Adhesive: step 5, image 1 of 2 Macbook Pro Glass  Replacement, Preparing Screen Adhesive: step 5, image 2 of 2
    • Remove the strips covering the adhesive on the new screen.
    • Heat the new adhesive strips evenly using the hair dryer.
  6. Macbook Pro Glass  Replacement, Applying the New Screen: step 6, image 1 of 2 Macbook Pro Glass  Replacement, Applying the New Screen: step 6, image 2 of 2
    • Place the new screen in position. Confirm that the new screen is properly aligned with the edges of the Macbook Pro.
  7. Macbook Pro Glass  Replacement, Attaching the New Screen: step 7, image 1 of 2 Macbook Pro Glass  Replacement, Attaching the New Screen: step 7, image 2 of 2
    • Using the screen cleaning cloth carefully press the edges of the screen to seal the adhesive.
  8. Macbook Pro Glass  Replacement, Remove Cover: step 8, image 1 of 1
    • Peel the protective covering off the new screen.
  9. Macbook Pro Glass  Replacement, Reheat the Adhesive: step 9, image 1 of 3 Macbook Pro Glass  Replacement, Reheat the Adhesive: step 9, image 2 of 3 Macbook Pro Glass  Replacement, Reheat the Adhesive: step 9, image 3 of 3
    • To insure the seal of the adhesive, reheat it again with the hair drying.
  10. Macbook Pro Glass  Replacement, Final Press: step 10, image 1 of 1
    • Finally, use the screen cleaning cloth and carefully press the edges of the screen one more time.
  11. Macbook Pro Glass  Replacement, You did it!: step 11, image 1 of 1
    • Enjoy your laptop with it's brand new screen!
Заключение
This guide provides all instructions necessary to dismantle and replace a Macbook Pro Screen.
38 участников успешно повторили данное руководство.
Akh1913
Участник с: 16.10.2015
1 201 Репутация
1 руководство автора
Команда
PIRL Gadget Garage Участник PIRL Gadget Garage
Community
9 членов
Автор 10 руководств
Комментариев: 18
How did you know the correct part number for your specific MacBook? Where did you source the glass?
frightanic.com - Ответить
I sourced my glass this eBay seller: http://www.ebay.com/usr/beetstech?_trksi...
To find the correct part, I followed iFixit's "ID your Mac" prompts in the parts store, then selected the glass panel from the list of compatible parts.
Hope this helps!
Noah Smith -
Is it useful for internal crack
tiffanyts - Ответить
FYI, OWC (Other World Computing, aka macsales.com) has the 15-inch glass for $25, and the 13-inch for $24:
https://eshop.macsales.com/item/Apple/MB... (15-inch)
https://eshop.macsales.com/item/Apple/MB... (13-inch)
…and I just discovered they even have the 17-inch:
One last comment: get the glass as hot as you can!
jiclark - Ответить
Does this work for the Late-2013 Retina MacBook Pro (15-inch)?
Brian Shiau - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 37
За последние 7 дней: 274
За последние 30 дней: 1,203
За всё время: 117,621
