Введение
The keyboard has 3 main parts, including the speaker cover, the heat sink, and the keyboard itself. You have to remove these in order to remove the keyboard.
Выберете то, что вам нужно
Turn the device upside down and then locate the battery latch near the front of the device.
Press firmly on each end of the speaker cover and slide it to the left.
I found it was easy to get a spudger over the left edge and lift it up a bit, then push the bar to the left, It pops right off after that.
Locate the six screws that secure the heatsink.
This is not necessary to remove the HDD. Go directly to step 20.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Еще один человек закончил это руководство.
