Macintosh PowerBook 165c Modem Card Replacement
Выберете то, что вам нужно
  1. Macintosh PowerBook 165c Modem Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Modem Card Replacement: шаг 2, изображение 1 из 1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Modem Card Replacement, Input/Output Door: шаг 3, изображение 1 из 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Modem Card Replacement: шаг 4, изображение 1 из 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Modem Card Replacement, Lower Case: шаг 5, изображение 1 из 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Modem Card Replacement: шаг 6, изображение 1 из 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Modem Card Replacement: шаг 7, изображение 1 из 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Modem Card Replacement: шаг 8, изображение 1 из 2 Macintosh PowerBook 165c Modem Card Replacement: шаг 8, изображение 2 из 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Modem Card Replacement: шаг 9, изображение 1 из 2 Macintosh PowerBook 165c Modem Card Replacement: шаг 9, изображение 2 из 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Modem Card Replacement, Modem Card: шаг 10, изображение 1 из 1
    • Orient the computer so the ports are facing you.
  11. Macintosh PowerBook 165c Modem Card Replacement: шаг 11, изображение 1 из 2 Macintosh PowerBook 165c Modem Card Replacement: шаг 11, изображение 2 из 2
    • Locate the Modem Card on the lower case.
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
    • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
  12. Macintosh PowerBook 165c Modem Card Replacement: шаг 12, изображение 1 из 1
    • Lift the modem card directly upward until it releases from the connector.
    • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
Заключение
John
Участник с: 10/12/11
88 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-3, Regan Fall 2011 Участник Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 членов
Автор 12 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 852
