Macintosh PowerBook 165c Motherboard Replacement
Выберете то, что вам нужно
  1. Macintosh PowerBook 165c Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Motherboard Replacement: шаг 2, изображение 1 из 1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Motherboard Replacement, Input/Output Door: шаг 3, изображение 1 из 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Motherboard Replacement: шаг 4, изображение 1 из 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Motherboard Replacement, Lower Case: шаг 5, изображение 1 из 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Motherboard Replacement: шаг 6, изображение 1 из 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Motherboard Replacement: шаг 7, изображение 1 из 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Motherboard Replacement: шаг 8, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 8, изображение 2 из 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Motherboard Replacement: шаг 9, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 9, изображение 2 из 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Motherboard Replacement, Modem Card: шаг 10, изображение 1 из 1
    • Orient the computer so the ports are facing you.
  11. Macintosh PowerBook 165c Motherboard Replacement: шаг 11, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 11, изображение 2 из 2
    • Locate the Modem Card on the lower case.
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws from the two corners.
    • The modem card is an optional component on the Macintosh 165c, and may not be included in all devices.
  12. Macintosh PowerBook 165c Motherboard Replacement: шаг 12, изображение 1 из 1
    • Lift the modem card directly upward until it releases from the connector.
    • If the modem card is difficult to remove, gently jostle it back and forth as you lift up.
  13. Macintosh PowerBook 165c Motherboard Replacement, RAM and PSRAM Expansion Card: шаг 13, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement, RAM and PSRAM Expansion Card: шаг 13, изображение 2 из 2
    • Locate and lift ram card directly up until connector releases.
    • Move the card back and forth gently if the connector does not release immediately.
  14. Macintosh PowerBook 165c Motherboard Replacement: шаг 14, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 14, изображение 2 из 2
    • Locate and lift the PSRAM expansion card vertically until connector releases.
    • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
    • The PSRAM expansion card is an optional component, and may not be included in all devices.
  15. Macintosh PowerBook 165c Motherboard Replacement, Daughterboard: шаг 15, изображение 1 из 1
    • Use T8 torx screwdriver to remove four, 7.7mm long screws from the perimeter of the daughterboard.
  16. Macintosh PowerBook 165c Motherboard Replacement: шаг 16, изображение 1 из 1
    • Life the daughterboard directly up to remove it from the connector.
    • If the daughterboard does not easily release from the connector, gently jostle it back and forth as you lift up.
  17. Macintosh PowerBook 165c Motherboard Replacement, Motherboard: шаг 17, изображение 1 из 1
    • Remove the three cylindrical silver spacers placed on top of the motherboard.
  18. Macintosh PowerBook 165c Motherboard Replacement: шаг 18, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 18, изображение 2 из 2
    • Lift up on the orange connector attached to the hard drive until it releases from the motherboard.
  19. Macintosh PowerBook 165c Motherboard Replacement: шаг 19, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 19, изображение 2 из 2
    • Open the white tab fastener by lifting up on both sides.
    • Remove the white ribbon cable by gently pulling it away from the opened tab fastener.
  20. Macintosh PowerBook 165c Motherboard Replacement: шаг 20, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 20, изображение 2 из 2
    • Open the white lock out tab located at the top of the motherboard.
    • Remove the black and orange ribbon cable by gently pulling it away from the opened tab fastener.
  21. Macintosh PowerBook 165c Motherboard Replacement: шаг 21, изображение 1 из 2 Macintosh PowerBook 165c Motherboard Replacement: шаг 21, изображение 2 из 2
    • Use needle nose pliers to remove the two, 5mm inch wide and 10.8mm long hex bolts from the lower left side of the motherboard.
    • To remove bolts with pliers, twist counter clockwise.
  22. Macintosh PowerBook 165c Motherboard Replacement: шаг 22, изображение 1 из 1
    • Lift up on the motherboard to remove it.
Заключение
Еще один человек закончил это руководство.
John
Участник с: 10/12/11
88 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-3, Regan Fall 2011 Участник Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 1,805
