Введение
This guide will teach you how to remove and replace the rear cover of a Mad Catz Dual Force 2 Pro controller. If you need to repair the controller or access the internals of your controller you will need to remove the rear cover.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the six 7 mm screws from the rear cover.
After removing the screws, you will be able to lift the rear cover of the controller.
Еще один человек закончил это руководство.
