Mad Catz Rock Band 4 Wireless Fender Power Button Replacement
Выберете то, что вам нужно
  1. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Outer Casing: шаг 1, изображение 1 из 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: шаг 2, изображение 1 из 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: шаг 3, изображение 1 из 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement, Power Button: шаг 4, изображение 1 из 1
    • Using a size J1 philips head screwdriver, remove the two black 5 mm screws (circled in red) from the back of the power button component. You can identify this by the code J5-B on the component.
  5. Mad Catz Rock Band 4 Wireless Fender Power Button Replacement: шаг 5, изображение 1 из 1
    • Using your hands, lift the small, rectangular circuit board off and follow the connecting cords to the main circuit board.
    • Unplug the cord connected to the battery component from the main circuit board.
Заключение
3 участников успешно повторили данное руководство.
Catherine Lintner
Участник с: 09/21/16
581 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-1, Cagle Fall 2016 Участник USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 членов
Автор 6 руководств
Один комментарий
I need two Rock Band 4 Home Button/Bluetooth Replacement Parts, where to locate??
My name is Robert.
Thank you in regards to whom can assist
Robert Houser Jr - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 26
За всё время: 3,161
