Mad Catz Rock Band 4 Wireless Fender Whammy Bar Replacement
Выберете то, что вам нужно
  1. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Outer Casing: шаг 1, изображение 1 из 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: шаг 2, изображение 1 из 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: шаг 3, изображение 1 из 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Whammy Bar: шаг 4, изображение 1 из 1
    • Using a size J1 philips head screwdriver, remove the four black 5 mm screws (circled in red) from the cover on the whammy bar component.
  5. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: шаг 5, изображение 1 из 1
    • Using your hands, pull off the black cover and put the spring that pops out aside.
  6. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: шаг 6, изображение 1 из 1
    • Using your hands, pull out the rectangular circuit board from the whammy bar component.
  7. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: шаг 7, изображение 1 из 1
    • Follow the cord for the circuit board from the whammy bar, and using your hands pull it out of the main circuit board.
  8. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: шаг 8, изображение 1 из 1
    • Pull out the whammy bar.
Заключение
Catherine Lintner
Участник с: 09/21/16
581 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-1, Cagle Fall 2016 Участник USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 18
За всё время: 1,619
