Введение
Use this as a guide to remove or replace the rubber part of the directional pad.
Запчасти
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Locate RS-DP-LS switch.
Pull upwards on the switch to remove it.
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
2 участников успешно повторили данное руководство.
Комментариев: 2
mi spiegate l'utilita di questa guida?vendere forse le pinzette e tutte le altre stronzatine che servono per riparare il fightpad?quando invece il pezzo più importante cioè il gommino non lo vendete....fate pena
Hi I don't speak Italian but I think you are asking "what is the purpose of this guide?". We made these as a project for university because I wanted to resolder a wire in this controller that came undone. For good measure we made a guide for each individual part although the real purpose of these guides was for the full disassembly and re soldering.
