Введение
Removing the FightPad's front case for replacing the case or front artwork.
Запчасти
Детали не указаны.
Use tweezers to completely remove the sticker from the rear of controller.
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
Use the plastic opening tool to pry the two cases apart.
Locate RS-DP-LS switch.
Pull upwards on the switch to remove it.
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
Remove the six buttons one by one by gripping the back of each one and pushing on them from the front.
Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
Remove the left and right shoulder buttons by sliding them out of their respective slots.
Еще один человек закончил это руководство.
