Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Removing the FightPad's front case for replacing the case or front artwork.
Запчасти
Детали не указаны.
  1. Use tweezers to completely remove the sticker from the rear of controller.
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases. Use the plastic opening tool to pry the two cases apart.
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Remove the two rubber side grips. Remove the two rubber side grips.
    • Remove the two rubber side grips.
  5. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  6. Locate RS-DP-LS switch. Pull upwards on the switch to remove it.
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  7. Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  8. Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board. Be careful with the wires connected to the circuit board itself as they are thin and delicate. When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  9. Remove the six buttons one by one by gripping the back of each one and pushing on them from the front. Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
    • Remove the six buttons one by one by gripping the back of each one and pushing on them from the front.
    • Use tweezers to remove the rubber part of the directional pad before you try to remove the shoulder buttons.
    • When reinserting the buttons make sure they are in the correct place and oriented correctly.
  10. Remove the left and right shoulder buttons by sliding them out of their respective slots.
    • Remove the left and right shoulder buttons by sliding them out of their respective slots.
  11. Pull the plastic piece out from the bottom of the controller. Pull the plastic piece out from the bottom of the controller.
    • Pull the plastic piece out from the bottom of the controller.
Заключение
Еще один человек закончил это руководство.
Eric
Участник с: 26.09.2012
96 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 1-7, Propen Fall 2012 Участник Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 1,235
