Введение
After you remove the back cover, you can get to any part of your RoadMate.
Выберете то, что вам нужно
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
Remove the back cover from the device by separating the back cover along its seam.
2 участников успешно повторили данное руководство.
