Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
Remove the back cover from the device by separating the back cover along its seam.
Pull the speaker cord, horizontally, by its base, away from the motherboard.
Remove the two screws on that are located on opposite sides of the board.
Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Carefully flip the circuit board out so you can get to the sensor easily.
Remove the tape holding the sensor to the display and take out the sensor.
Еще один человек закончил это руководство.
