Введение
This guide will walk through the steps of replacing a damaged or unresponsive digitizer/LCD of a Magellan RoadMate 2120T-LM. Before replacing the touch-screen, check for software updates from Magellan to rule out software issues.
Выберете то, что вам нужно
Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
Pull up on the brown tab holding down the ribbon.
Lift up on the motherboard and remove it from device.
Pry back on the plastic shell surrounding the touchscreen and remove the screen.
