Введение
Cracked plastic casing? This guide will help you replace the back cover of the Magellan RoadMate 5236T-LM.
Выберете то, что вам нужно
Place the device face down on a flat surface.
Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
Gently wedge a plastic opening tool into the seam along the side of the device.
Slide the tool along the seam to pry apart the front and back covers.
A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
Use tweezers to disconnect the ZIF connector from the motherboard.
Еще один человек закончил это руководство.
