Magellan RoadMate 5265T-LMB Screen Replacement
Выберете то, что вам нужно
  1. Magellan RoadMate 5265T-LMB Screen Replacement, Screen: шаг 1, изображение 1 из 1
    • Place the device on a flat surface with the screen facing down.
    • Remove the screws on the four corners of the device with a phillips head, size 0 screwdriver.
    • Be sure to keep track of where you place the screws. A magnetic project mat works great for this.
  2. Magellan RoadMate 5265T-LMB Screen Replacement: шаг 2, изображение 1 из 1
    • Using the plastic opening tool, gently pry apart the front and back casing panels around the edges of the device. While doing this the clips will gently be pried apart allowing you to separate the front and back casings.
    • There is a ribbon cable that will still connect the front panel to the motherboard.
  3. Magellan RoadMate 5265T-LMB Screen Replacement: шаг 3, изображение 1 из 2 Magellan RoadMate 5265T-LMB Screen Replacement: шаг 3, изображение 2 из 2
    • The ribbon cable is attached to the motherboard by a ZIF (Zero Insertion Force) connector.
    • Using the nylon or metal spudger, gently pop up the ZIF connector tab and remove the ribbon cable. This will allow you to separate the front panel from the motherboard.
    • Gently pull the front panel away and set it on your workstation.
  4. Magellan RoadMate 5265T-LMB Screen Replacement: шаг 4, изображение 1 из 2 Magellan RoadMate 5265T-LMB Screen Replacement: шаг 4, изображение 2 из 2
    • Use the plastic opening tool to push back the casing clips that hold the screen in place.
    • Applying light pressure against these clips will allow you to safely remove the screen from the front casing.
    • Once the screen has been removed, gently place it down on your workstation.
Заключение
Shannon McKeown
Участник с: 10/22/15
513 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 5-4, Gulbrandsen Fall 2015 Участник UMass Dartmouth, Team 5-4, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G4
3 членов
Автор 5 руководств
Один комментарий
In the "what you need," it would be helpful to provide a source for the replacement screen. I have not found the screen in my online search.
Thomas Benedum - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 437
