Введение
If you notice any sharp, moving components outside of your NutriBullet base, then use this replacement guide to learn how to remove and replace the base.
Выберете то, что вам нужно
Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
Once the screws are removed, use slight tension to pull the plastic base up.
2 участников успешно повторили данное руководство.
3 Комментариев
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Where can you buy the base to replace?
