Magic Trackpad Battery Replacement
Выберете то, что вам нужно
  1. Magic Trackpad Battery Replacement, Batteries: шаг 1, изображение 1 из 2 Magic Trackpad Battery Replacement, Batteries: шаг 1, изображение 2 из 2
    • Use a spudger or coin to twist out the battery door.
  2. Magic Trackpad Battery Replacement: шаг 2, изображение 1 из 1
    • Slide out the two AA batteries.
Заключение
3 участников успешно повторили данное руководство.
Ronnie
Участник с: 10/22/12
3 462 Репутация
Автор 5 руководств
4 Комментариев
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - Ответить
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - Ответить
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz -
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 17
За последние 30 дней: 104
За всё время: 12,445
