Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
Using your philips screwdriver, remove the two screws at the base of the disc drive. (See image)
Remove the two screws on either side of the green circuit-board as seen in the photos. Once the screws are removed, gently lift the board so you can remove the disc drive. BE CAREFUL! The board is still attached to the base of the DVD player. You just need to lift it enough to pull the disc drive out.
You can now gently lift the disc drive out of the the DVD player. BE CAREFUL! The disc drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
