Введение
A damaged or old mailbox flag can make the entire mailbox look worn. Luckily, it is easy to replace just the flag.
Place the bracket into the flag - this will help to secure it to the mailbox.
Insert the bracket of the assembled flag through the holes on the outside of the mailbox.
Push the flag keeper through the bracket until the flag reaches the desired tightness.
You are finished! Stand your flag up to ensure it works and is at the desired tightness.
If you would like your flag tighter, push the flag keeper in further.
To take the flag off your mailbox, follow these instructions in reverse order.
2 участников успешно повторили данное руководство.
3 Комментариев
so where do I buy the ‘flag keeper” to insert in the bracket?
Do you have one with 3 holes, maybe an older style?
