Введение
This guide shows how to access the interior of your Mainstays White 12 Cup Drip Coffee Maker.
Выберете то, что вам нужно
Inspect the bottom of the coffee maker and find the small hole near the middle of the lid. There should be a screw inside this hole.
Use a Phillips screwdriver remove that screw 13 mm screw on the bottom of the coffeemaker.
Once that screw is off, locate the 2 push latches on the back and bottom side of the coffee maker.
Use a pry tool to initially dislodge the previously mentioned latches.
Use a prying tool to pry the bottom of the coffee maker off, pushing the sharper end into the crevice and using the tool like a lever to lift the lid off.
Once you have dislodged both latches, simply pull the lid up and away from the front of the coffeemaker and the lid should be completely off.
Once the bottom is off, you should be able to access any part of the coffee maker's wiring and circuits.
