Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to remove and replace the chain tensioner module in a Makita chainsaw.
Optional Tools:
- Chainsaw scrench
Выберете то, что вам нужно
Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
Remove the four 12 mm long T27 screws securing the chain brake cover.
Twist the tension screw clockwise until the slide bar stops at the right end.
Remove the single 15.7 mm long T27 screw holding the chain tensioner assembly in place.
If the packing ring did not come out with the assembly, remove it from the recess.
Lightly lubricate the packing ring and press it into the back of the adjustment screw.
Slide the adjustment screw into the tensioning assembly such that the gears mesh together.
Slide the shaped plastic bearing onto the end of the assembly.
Lightly lubricate all moving surfaces.
Line up the tensioning assembly with its recess in the chainsaw and push it into the recess.
5 участников успешно повторили данное руководство.
