Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement
Выберете то, что вам нужно
  1. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the sprocket guard plate: шаг 1, изображение 1 из 1
    • Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
  2. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement: шаг 2, изображение 1 из 1
    • Remove the sprocket guard plate.
  3. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the chain and guide bar: шаг 3, изображение 1 из 1
    • If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
    • During reassembly, if you are reinstalling the chain and guide bar, follow the manufacturers instructions on proper chain tensioning techniques.
  4. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Release the chain brake: шаг 4, изображение 1 из 2 Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Release the chain brake: шаг 4, изображение 2 из 2
    • Pull the hand guard towards the tubular handle until you hear a click to release the chain brake.
  5. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the stop ring: шаг 5, изображение 1 из 2 Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the stop ring: шаг 5, изображение 2 из 2
    • Use a small flathead screwdriver or snap ring pliers to pry and remove the stop ring from the axle.
  6. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the flat washer: шаг 6, изображение 1 из 1
    • Slide the flat washer off of the axle and remove it.
    • Re-assembly tip—be sure to re-install the washer in the correct orientation as shown in the picture.
  7. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the rim sprocket: шаг 7, изображение 1 из 1
    • Slide the rim sprocket off of the axle and remove it.
    • Re-assembly tip—be sure to re-install the rim sprocket in the correct orientation as shown in the picture.
  8. Makita Chain Saw EA6100PR 2017 Clutch Drum Replacement, Remove the clutch drum: шаг 8, изображение 1 из 1
    • Slide the clutch drum off of the axle and remove it.
    • During re-assembly, lubricate all moving surfaces, such as the axle.
Заключение
2 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
252 729 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 2,326
