Введение
These instructions will show you how to replace the rear axle of your Makita DLM431 lawn mower.
Выберете то, что вам нужно
Remove lock key and the grass-catching basket.
Put the lawnmower on its head and store it safely.
Loosen the nut of the wheels with a 13mm spanner.
Pull the wheel off the axle
Loosen the nut of the connection between rear axle and axle adjustment with the 13mm nut.
Pull off the axle adjustment linkage.
Remove screws with a Phillips screwdriver.
Push the axle holder backwards through the fairing to expose the axle.
Congrats! Now follow the steps in reverse order to reassemble your unit.
2 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
carlotremoladaпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
