Введение
The electrical cord is responsible for the transfer of energy from the socket to the angle grinder. If the cord is damaged or isn't functioning properly the angle grinder will not work or will even become hazardous.
Выберете то, что вам нужно
Place your finger in the gap in front of the switch.
At the base of the device, push the switch lever into the 'on' position.
Pull back the plastic clip and pull the internal switch up and out of the cavity.
Remove the two 10 mm screws holding the power cord leads in place using a Phillips #02 screwdriver.
Unscrew the 2 mm tapping screw using a Phillips #02 screwdriver.
Lift the clasp up and out to remove it.
Еще один человек закончил это руководство.
