Введение
This guide will show you the necessary steps to locate and replace the gear select switch. It shows how to remove the battery and the outer casing in order to locate the gear select switch.
Выберете то, что вам нужно
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the backplate and pull away from the drill.
Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the outer casing and pull away from the drill.
Pull the silver metal clip located towards the back of drill away from the motor assembly.
Gently grip the front of the motor assembly and pull it out of the plastic casing.
Push gear select switch forward.
Lift the gear select switch to separate it from the motor assembly.
3 участников успешно повторили данное руководство.
