Marshall Emberton Charging Port Bay Replacement
Выберете то, что вам нужно
  1. Marshall Emberton Charging Port Bay Replacement, Charging Port Bay: шаг 1, изображение 1 из 1
    • In order to start uncrewing any of the screws off the speaker we have to take off the protective cover.
  2. Marshall Emberton Charging Port Bay Replacement: шаг 2, изображение 1 из 1
    • In order to get inside the speaker you will have to unscrew the screws on the side.
  3. Marshall Emberton Charging Port Bay Replacement: шаг 3, изображение 1 из 1
    • Prying the front of the speaker where it says "Marshall" in order to get into the insides of the speaker.
  4. Marshall Emberton Charging Port Bay Replacement: шаг 4, изображение 1 из 3 Marshall Emberton Charging Port Bay Replacement: шаг 4, изображение 2 из 3 Marshall Emberton Charging Port Bay Replacement: шаг 4, изображение 3 из 3
    • Once the "Marshall" part of the speaker is off this is how it will look. It's another protective layer that needs to be removed.
    • When removing all of the eight 1cm screws that are on the protective layer, will give us access to the insides of the speaker.
  5. Marshall Emberton Charging Port Bay Replacement: шаг 5, изображение 1 из 1
    • Once speaker is opened the motherboard will be the first thing that is seen. Then you will have to look for the 6 1cm screws (Shown in photograph)
  6. Marshall Emberton Charging Port Bay Replacement: шаг 6, изображение 1 из 2 Marshall Emberton Charging Port Bay Replacement: шаг 6, изображение 2 из 2
    • Once screws are all off, there will be a wire (red/black) that will need to be disconnected from the motherboard.
    • Once the first wire is disconnected from the motherboard, you will then have to flip it over and do the same on the bottom side of the motherboard.
    • Once those wires are disconnected from the motherboard it will simply come right out.
  7. Marshall Emberton Charging Port Bay Replacement: шаг 7, изображение 1 из 2 Marshall Emberton Charging Port Bay Replacement: шаг 7, изображение 2 из 2
    • Once the motherboard is pulled out, you will be able to locate the charging port on the left side.
    • Once it is located there will be 2 1.2 cm screws that will need to be removed.
    • Once removed the charging port will be out.
Заключение
2 участников успешно повторили данное руководство.
Asia Baldwin
Участник с: 09/26/22
697 Репутация
Автор 5 руководств
Команда
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Участник CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 членов
Автор 5 руководств
6 Комментариев
Where can i buy that part? In europe. Thank you.
Ricardo - Ответить
Where can I purchase a replacement charging port in uk
G-REG - Ответить
Where can I buy the usb port in the US?
SLE - Ответить
Hello. Nice guide for this. Next question😉 where can i buy a New bay? 🤔 Mine is very boken 😆
/Peter
Peter Lövan Löfqvist - Ответить
Hi where can i buy the part?
Ricardo - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 32
За последние 30 дней: 130
За всё время: 2,046
