Запчасти
No parts specified.
  1. First be sure to turn the power switch to the off position.
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Now remove the battery. On the back of the device locate the battery cover. Remove it by pushing down on the clip.
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners. Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  6. Use a soldering iron to disconnect the two wires from the speaker.
  7. Remove the two 7/16" screws located in the bottom left and top right corners with a phillips head screw driver. After removing the screws, the metal clips will need to be removed as well. Remove the two 7/16" screws located in the bottom left and top right corners with a phillips head screw driver. After removing the screws, the metal clips will need to be removed as well.
    • Remove the two 7/16" screws located in the bottom left and top right corners with a phillips head screw driver. After removing the screws, the metal clips will need to be removed as well.
  8. You may now remove the speaker by pulling it straight out.
    • You may now remove the speaker by pulling it straight out.
Итог
MacKinley
Участник с: 22.10.2013
675 Reputation
Автор 5 руководств
University of Maryland, Team 1-1, Shastany Fall 2013 Member of University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 членов
Автор 5 руководств
4 Comments
So where do we find a replacement speaker? If no parts are required what is the point in taking the speaker out?
Patrick Gillett - Ответить
This speaker unavailable in Marlins. Any online sources. How should an untutored amateur repairer describe the replacement in order to get the right thing
Any speaker that will fit should work. Might want to check to make sure the Watts they consume are the same. I imagine that if you put a speaker in that consumes more Watts you could potentially over heat the power supply or other components.
MacKinley - Ответить
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 20
All Time: 2,768
