Введение
Detailed images and descriptions will be provided to show the user how to replace the lithium battery.
Выберете то, что вам нужно
Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Desolder the battery connections from the motherboard. Learn how to solder components here!
Еще один человек закончил это руководство.
