Matsunichi MarquisPad MP977 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: шаг 1, изображение 1 из 1
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 2, изображение 1 из 3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 2, изображение 2 из 3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 3, изображение 1 из 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 3, изображение 2 из 2
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 4, изображение 1 из 1
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 5, изображение 1 из 1
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 6, изображение 1 из 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 6, изображение 2 из 2
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 7, изображение 1 из 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: шаг 7, изображение 2 из 2
    • Last, Insert the new camera into the pinhole camera slot.
Заключение
Kathryn Sherlock
Участник с: 03/24/15
127 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 Участник UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G1
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 227
