Mavic 2 Controller Joystick Replacement
Выберете то, что вам нужно
  1. Mavic 2 Controller Joystick Replacement, Controller Joystick: шаг 1, изображение 1 из 1
    • Use a Phillips #0 screwdriver to remove the two 5.7 mm screws from the bottom of the controller.
  2. Mavic 2 Controller Joystick Replacement: шаг 2, изображение 1 из 2 Mavic 2 Controller Joystick Replacement: шаг 2, изображение 2 из 2
    • Insert the opening tool to separate the small plastic part from the main housing of the controller that was unscrewed in the last part.
    • Remove the remaining plastic cover by unclipping the tabs located next to the charging port. Detach the clips that are below the screen that are holding the plastic part in place.
    • Now you should be able to pull out the bottom cover piece.
  3. Mavic 2 Controller Joystick Replacement: шаг 3, изображение 1 из 3 Mavic 2 Controller Joystick Replacement: шаг 3, изображение 2 из 3 Mavic 2 Controller Joystick Replacement: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a Phillips #0 screwdriver to remove the two 5.7 mm screws that are secure the top cover.
    • Remove the cable connecting the joystick to the board with a pair of tweezers.
    • There is a cable on both sides, so get both.
    • Go around the top cover, undoing all clips holding the top cover on. Insert the opening tool in between the top cover and the lower base of the controller.
  4. Mavic 2 Controller Joystick Replacement: шаг 4, изображение 1 из 2 Mavic 2 Controller Joystick Replacement: шаг 4, изображение 2 из 2
    • Now that the top cover is removed flip it over and you will see something similar to picture one.
    • You will need to use the Phillip #0 to remove the four screws holding the joystick to the top cover plate.
    • This will allow you to replace the joystick with a new one.
Заключение
Quentin Rodriguez
Участник с: 11/09/23
118 Репутация
1 руководство автора
Команда
IUPUI, Team 2-3, Harley Fall 2023 Участник IUPUI, Team 2-3, Harley Fall 2023
IUPUI-HARLEY-F23S2G3
3 членов
Автор 4 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 42
За всё время: 543
