Введение
Перейти к шагу 1 ↓- Turn drone upside down to expose underside plate.
- Begin to remove all 8 screws from the plate . Remember the 2 middle screws are bigger than the other 6 so set those aside separately.
- Pull plate off, exposing the main board.
- Detach 3 ribbons on the top of the board. Near the head of the drone. Use spreader.
- Remove screw holding circuit board in. 1 near the top, 2 near the bottom.
- Pop of all 4 antennas at the bottom of the circuit board. Use spreader.
- Pull away antennas and remove board carefully.
- Replace new circuit board.
- Attach 3 ribbons.
- Attach 4 antennas.
- Screw circuit board back in.
- Place the plate back on and screw back in all 8 screws.
Выберете то, что Вам нужно
Инструменты
After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
Then remove the old board. Replace the new board you have and repeat the process in reverse.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
