Введение
If the Maylong MN-1000P starts but then shuts down or your screen is blue and nothing happens, it may be a faulty motherboard. Motherboards are one of the more difficult parts to replace, but this guide will make it easier for you.
Запчасти
Детали не указаны.
Place the netbook top down, with the opening of the netbook facing you.
Remove the sticker in the middle of the netbook.
Remove the middle 6mm Phillips #00 screw.
Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
Pull the top of the computer and the back side of the computer away from each other until they are detached.
Flip the entire computer over so you can see both the screen and keyboard.
Remove all the black circular pads from around the screen.
Remove all 6mm Phillips #00 screws from around the screen bezel.
Using a plastic opening tool, pry off the screen bezel.
After detaching the screen bezel, pull up on the bezel near the hinge area.
Use tweezers to gently pull on the black and white wires at the top of the netbook until the white connector detaches.
Use your fingers to pull on the green, red, black, and white intertwined wires at the bottom of the netbook until the white connector detaches.
Flip the computer over.
Disconnect the red, green, black, and white intertwined wires from the connector to the motherboard.
Remove the black tape holding down the red, green, black, and white intertwined wires.
Remove the screen.
Remove the two 6mm silver screws from the small circuit board connected to the motherboard by the red and black wires.
Remove the two small black speakers on the corners connected to the motherboard by the black and red wires.
Disconnect the black connectors from the motherboard by pulling on the white ribbon cable.
Remove the black covered wire connected to the motherboard by pulling the white ribbon cable away from the motherboard.
Using a spudger, remove the gold cylinder out of the indent at the bottom of the computer.
Lift the motherboard up.
Remove the motherboard by detaching the clear tape from underneath the motherboard.
