Введение
This guide will show you how to replace the water filter on a Maytag MF D2561KES refrigerator. It is recommended that the water filter be replaced every six months. Drinking unfiltered water can be potentially unhealthy and sometimes it tastes bad. Learning how to replace your water filter and using filtered water with a reusable water bottle is more cost effective and will save the environment. Reducing plastic water bottle usage is a great goal and this maintenance is very easy to do!
Выберете то, что вам нужно
Locate your water filter in the fridge.
On this fridge, it will be located above the top shelf on the right hand side.
Make sure that the water filter you purchased is recommended for your refrigerator brand.
Open the filter container. using the push button
Remove the old water filter and drain the excess water in the filter into the sink.
Extra water should be dumped into the sink before it is thrown away.
Get a large container and press the water button and hold it for roughly 60 seconds.
After the water has been run for 60 seconds the water is again filtered and ready to drink.
Here is how you can replace a water filter for a refrigerator. Removing the filter could just use the first 4 steps.
