Введение
This guide will show you how to remove the dashboard for a Mazda 323 Protege.
Выберете то, что вам нужно
Upgrading your Dashboard or what ever, you might want to open your Dashboard, this is the Easy Way...
Open your door, you will see a Plastic Cover, remove it with a screwdriver or by hand.
Now to the magic: usualy, one must remove the steering wheel in order to continue. There are 2 easy alternatives:
Option 1: With height adjustable steering wheel: remove the screw holding the top steering column trim and lower the column to its lowest by releasing the lever. Remove the top steering column trim.
Option 2: Without height adjustable steering column: Remove all 4 screws of the steering column trim. Afterwards: remove the large golden screws. Be carefull whilst removing the last one: hold the column tight with one hand or it will fall, since it is screwed to nothing else.
After Option 1 or 2: Pull the trim out of its holding clips. Disconnect all wires, except for clock and hazard switch. Slowly remove the trim, in case of Option 1: you might have to slightly bend the trim, be carefull. Afterwards: Rotate the trim 180° around the clock wire.
Finally: Remove the 4 screws holding the dashboard. Disconnect the 3 connectors and speed wire and you are done!
Еще один человек закончил это руководство.
