Введение
If your mechanical pencil no longer produces lead - either no lead is produced from pressing the dispenser, or the dispenser cannot be compressed - this guide can help you restore function. An Xtra Strong Mechanical Pencil is used in this guide, although the process is similar for other brands. This fix targets the replacement of broken or jammed springs, which anyone of any technical skill level can accomplish. Your mechanical pencil will need to be disassembled, the old spring removed and replaced, and then reassembled. No special considerations or tools are required.
Инструменты
Запчасти
While keeping the shaft depressed, slide the gold dispenser ring back into the sleeve to expose the dispenser.
Use pliers to grasp the dispenser perpendicular to the open split.
Apply pressure and pull the dispenser straight out from the shaft and sleeve. This may be difficult.
Place the dispenser and dispenser ring into the sleeve in the order it was removed.
Place the new spring and old shaft into the sleeve in the order it was taken out.
Using your thumb or a hard surface pressed against the dispenser, push the shaft into the dispenser.
To reassemble your device, follow steps 1 - 3 of these instructions in reverse order.
Еще один человек закончил это руководство.
