Введение
If these microswitches on the drive do not work precisely, the machine will not work properly and the drive may be damaged. Replacing the Cherry D41X microswitches is not very difficult.
Note: you can also open the drive without unscrewing it completely. Then skip the corresponding steps.
Выберете то, что вам нужно
Remove the water tank and drainage tray.
Remove the side cover and remove the brewing unit.
Remove all coffee beans.
Press carefully into the slits on the sides using a minus screwdriver or a flat metal spatula, to release the clasps on the upper surface. These may be well tight and you have to use some force.
You should have created a separation between the upper surface and side panels. Now lever the upper covering away using a plastic tool. This may be quite stuck and you may apply some force.
Open the cover over the drive. It is held by latches.
Remove the cover.
The two microswitches are exposed.
Follow the the steps in reverse order to reassemble your device.
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
