Введение
If the lid spring on your Memorex CD Alarm Clock breaks, this guide will show you how to replace it.
Выберете то, что вам нужно
Turn the clock radio over so the bottom is facing up.
Pull the tab upward and remove the cover from the battery compartment.
Remove the batteries.
Remove the five screws on the bottom of the device with a screwdriver.
Grasp the top and bottom and gently pull apart.
Locate the spring and the spring's retaining piece.
Use a screwdriver to remove the screw and the retaining piece.
