Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If you need to replace the back panel of the Minimove boombox, follow the steps from this guide. This guide will involve moderate disassembly of the device, including the removal of the back covering and base.
Выберете то, что вам нужно
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
Remove the two 8 mm screws with a Phillips #1 screwdriver.
Remove the two 12 mm screws with a long Phillips #1 screwdriver.
To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
Carefully pull the panel off.
Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
Use the Phillips #1 screwdriver to remove the four 12 mm screws.
Remove the five 6 mm screws at the top with the same screwdriver.
Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
Use moderate force to pry it open and take the cover off.
3 участников успешно повторили данное руководство.
