Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
You may have broken the display to your Minimove boombox. This guide will direct you in removing the current display and re-installing a new one. The display is part of a daughterboard that must be replaced altogether if your display is not working. This guide will require extensive disassembly of the Minimove.
  1. Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. This step will require at least a 30 mm Phillips #1 screwdriver.
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. The bottom panel screws and screw covers must be removed in order to access the back panel.
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. To remove the back panel, use the plastic opening tool and gently work around the outline of the panel.  The outline wraps around the sides and can be spotted at the top back of the device. To remove the back panel, use the plastic opening tool and gently work around the outline of the panel.  The outline wraps around the sides and can be spotted at the top back of the device.
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  6. Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed. After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands. Carefully pull the panel off.
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  7. Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  8. If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom. If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  9. Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  10. Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  11. Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner. Use moderate force to pry it open and take the cover off.
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
  12. Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free.
    • Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly.
    • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
  13. Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device. Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device.
    • Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device.
  14. Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors. Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors.
    • Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors.
  15. Follow the wires attaching to the iPod adapter and use the IC (Integrated Circuit) extractor to remove the indicated wire connectors from the motherboard. Pinch the IC extractor just under the top lip of the wire housing. Pinch the IC extractor just under the top lip of the wire housing.
    • Follow the wires attaching to the iPod adapter and use the IC (Integrated Circuit) extractor to remove the indicated wire connectors from the motherboard.
    • Pinch the IC extractor just under the top lip of the wire housing.
  16. Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver. Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver.
    • Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver.
  17. Remove the iPod adapter by sliding it out of the slot.
    • Remove the iPod adapter by sliding it out of the slot.
  18. Locate and unscrew the four 8mm screws (in red) along the edge with a Phillips #1 screwdriver. Unscrew the two 12mm screws (in orange) on the inside of the daughterboard.
    • Locate and unscrew the four 8mm screws (in red) along the edge with a Phillips #1 screwdriver.
    • Unscrew the two 12mm screws (in orange) on the inside of the daughterboard.
  19. Slide out the iPod adapter housing by applying moderate pressure with your two index fingers from the inside as well as your thumb downward.
    • Slide out the iPod adapter housing by applying moderate pressure with your two index fingers from the inside as well as your thumb downward.
  20. Remove the four 8 mm screws using a Phillips #1 screwdriver. Remove the four 8 mm screws using a Phillips #1 screwdriver.
    • Remove the four 8 mm screws using a Phillips #1 screwdriver.
  21. The speaker housing may require more force than expected to remove because it is held together by a thin layer of rubber. Do not be afraid of using more force if you are unable to remove it on the first try. When the housing is removed the rubber adhesive will come off. This should not effect your device's functionality in any way.
    • The speaker housing may require more force than expected to remove because it is held together by a thin layer of rubber. Do not be afraid of using more force if you are unable to remove it on the first try.
    • When the housing is removed the rubber adhesive will come off. This should not effect your device's functionality in any way.
    • Grab the outside of one speaker housing and pull outwards (starting with the top) while holding the main casing still with your other hand.
    • Remove the other housing on the opposite side the same way.
  22. Be careful when removing the daughterboard. There are still two wires connecting the display daughterboard to the radio motherboard which can be damaged or ripped if recklessly removed. Gently lift the display daughterboard straight up and remove it from the case.
    • Be careful when removing the daughterboard. There are still two wires connecting the display daughterboard to the radio motherboard which can be damaged or ripped if recklessly removed.
    • Gently lift the display daughterboard straight up and remove it from the case.
  23. To finish, disconnect the two wires outlined in red rectangles that are connected to the motherboard using the IC extractor. Pinch the IC extractor just under the top lip of the wire housing and pull firmly out.
    • To finish, disconnect the two wires outlined in red rectangles that are connected to the motherboard using the IC extractor.
    • Pinch the IC extractor just under the top lip of the wire housing and pull firmly out.
Заключение
2 участников успешно повторили данное руководство.
Devan Carlson
Участник с: 31.01.2014
121 Репутация
1 руководство автора
Команда
Cal Poly, Team 2-9, Amido Winter 2014 Участник Cal Poly, Team 2-9, Amido Winter 2014
CPSU-AMIDO-W14S2G9
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 475
