Mercedes W123 Diesel Fuel Filter, Primary Replacement
Выберете то, что вам нужно
  1. Mercedes W123 Diesel Fuel Filter, Primary Replacement, Fuel Filter, Primary: шаг 1, изображение 1 из 1
    • Here is your clear fuel primary filter. It is located directly next to the fuel primer pump.
  2. Mercedes W123 Diesel Fuel Filter, Primary Replacement: шаг 2, изображение 1 из 1
    • Begin by loosening this hose clamp, at the top of the primary filter, nearest the engine.
    • Pull the primary filter up and out of this hose. A small amount of fuel will leak out, consider putting a towel, plastic bag, or other appropriate catch underneath.
  3. Mercedes W123 Diesel Fuel Filter, Primary Replacement: шаг 3, изображение 1 из 1
    • Now loosen the clamp on the bottom of the primary filter, further from the engine.
    • You will now be able to pull the filter out the rest of the way. The fuel in it will drain out, catch it with towel or something similar.
  4. Mercedes W123 Diesel Fuel Filter, Primary Replacement: шаг 4, изображение 1 из 1
    • Here is the old primary filter, removed from the car. Note the large chunks of debris in the filter.
  5. Mercedes W123 Diesel Fuel Filter, Primary Replacement: шаг 5, изображение 1 из 1
    • You can see here the new primary filter. Note that the filter is usually marked with an arrow noting the direction of fuel flow. It should be installed with this arrow pointing towards the engine.
  6. Mercedes W123 Diesel Fuel Filter, Primary Replacement: шаг 6, изображение 1 из 1
    • Install the new filter by retracing the steps so far, just backwards.
    • This is a good time to consider replacing the large secondary filter. If you would like guidance on this, see the secondary fuel filter replacement guide.
    • Then, pump the primer pump on the car until the primary filter fills with fuel. It's normal for there to be a small air bubble in the primary filter but it should be mostly clear.
Заключение
When finished, run the engine to ensure it's been primed properly.
13 участников успешно повторили данное руководство.
Nicolas Siemsen
Участник с: 12/06/13
39 010 Репутация
Автор 79 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 521 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 87
За всё время: 16,732
