Введение
This repair guide will show you how to replace the metal contact points within the battery compartment of the remote controller for the MerchSource the Black Series Boat Racers device.
Выберете то, что вам нужно
Turn the remote controller over to the back.
Using a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
Lift the metal tab until it is straight and can move through the slot in the battery compartment.
Flip the remote controller to the external side and slide the metal connections in the battery compartment straight up.
Slide the new connections straight down into the slot in the battery compartment, flip to the internal side, and bend the metal tab until it's parallel with the battery compartment.
