Введение
Have you ever wanted to add accessory's to your oculus quest but were afraid to break something, or simply not know how? In this guide I will go over how to apply the Meta Quest Active Straps for the oculus quest 3 controllers. I will guide you step-by-step to ensure you do not break anything and know how to properly apply the accessory.
Выберете то, что вам нужно
First, you will want to pick up any of the controllers to begin replacing the wrist strap.
Adjacent to the controller's joystick is a white triangle button.
You need to press down firmly on the button to open the controller's battery compartment.
Once you open the compartment, pinch and pull up the strap to disconnect it from the controller.
With the new wrist strap, push the black clip down into the now-empty small compartment to connect your new strap to the controller.
You can close the battery compartment using the new cover connected to the controller strap.
Put the controller in your hands to see if you need to adjust the fit of the strap.
If Adjustments are needed, you can pull or push the strap through the clip's hole.
Once you have followed all these steps, you will have properly applied the accessory to your oculus quest 3 controllers.
Еще один человек закончил это руководство.
