Введение
Follow this guide to replace the photocell on a Mi-T-M heater model MH-0190-0M10.
Выберете то, что вам нужно
Flip the power switch into the OFF position.
Unplug any extension cords from the included power cord.
Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
Use needle nose pliers to remove the wire with the blue connector.
Remove the wire with the clear connector.
Remove the right-side cover.
Use your fingers to disconnect the white wire harness labeled CN3 on the main PCB assembly.
Feed the photocell wires through the opening in the lower cover.
Remove the photocell.
