Введение
There are two batteries in the band, located in the side panels. One battery compartment contains a vibrator, but the replacement steps are essentially the same.
Warning: The following guide is likely to ruin the water resistance of the device.
Выберете то, что вам нужно
Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
4 участников успешно повторили данное руководство.
5 Комментариев
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon -
Will this be dangerous?
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
