Введение
Lumia 435 RM1068, RM-1069, RM1070, RM-1071
Lumia 532 RM-1032, RM1034
How to disassemble Lumia 435, Lumia 532 and replace the broken touch screen glass.
Выберете то, что вам нужно
Видео обзор
Switch off the phone.
Remove the battery and any inserted SIM and memory cards.
Use a screwdriver Torx T6 and remove the 4x black screws.
There are several plastic locking clips hold the back cover to the frame.
Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
Unhook:
the touch screen flex cable
the LCD Display flex cable
Use a plastic tool lift up and remove the Logic board.
The Display metal shield is locked to the frame by 4x locking clips.
Use a tool with a sharp tip and careful unlock them and remove the shield.
The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
Put some transparent scotch tape to prevent the glass from shattering.
Warm the glass for a minute to make adhesive soften.
Start the separation from the middle of the frame, where the contact area is smaller.
When you finished with the separation the glass, clean the frame from the old adhesive.
Install the new touch screen and start to reassemble the device.
5 участников успешно повторили данное руководство.
Один комментарий
Is the lcd adhesive just on the edges of the lcd or covering the entire thing?
